Old 07-14-2022, 09:04 AM
ERA174's Avatar
ERA174 ERA174 is offline
Cobra Make, Engine: ERA 427, 482ci sideoiler
If you don’t already know, ERA has an owners only website with a boatload of manuals and other technical information for their cars. I would not try to reinvent the wheel, ERA usually will have whatever you need for your specific ERA car. Go to the ERA owners only website, if you don’t have the address for said website ERA can provide you with it. You can then view/download/print the specific literature for your build#. The manual will explain the brake balance bar setup(longer rod for front master), the front master requires more stroke than the rear to engage the brake pads with the rotor. After reading the pertinent ERA literature, I believe everything will fall in line for you. I strongly recommend staying with replacement parts used/recommended by ERA, they’ve been doing this for a long time and I have always found them to be very helpful.
