Old 07-14-2022, 03:49 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
ERA 174, your suggestion helped a ton because I was able to correctly align the front/rear brake balancer to the correct position.
Strictlypersonl thank you for the link to SSBC.
I didn't realize but I have the Big Brake front end, which I believe is a 4 piston?
Bob P said they have several replacement calipers on order - so in the meantime, we're going to flush the brake lines, bleed out and run clean fluid and this should be a vast improvement over current condition.
Here is my front brake...
https://uniim1.shutterfly.com/render...&ts=1657838743
