Old 07-18-2022, 06:16 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I’ve got several of the parts, including the alternator pulley and I believe I have the case also. I also reproduce the correct alternator mounting bracket casting (in steel not aluminum) with the correct logo and adjusting arm. I also have a set of the correct body KONI shock absorbers, intake manifold and cast aluminum oil pan. NOS water pump mounted fan blade……
