Thread: Coyote Owners
Old 07-21-2022, 09:42 PM
eschaider's Avatar
Originally Posted by tims210 View Post
I just did a pan capacity test per eschaider's recommendation. I used water instead of oil. To the baffle it held 5.25 qts. Going any higher will introduce oil into the front chamber. My filter holds 1/2 a qt. This equates to 5.75 qts. That's a difference of 3.75 qts from Moroso's advertised capacity of 9.5. I know these Coyote's have more oil flowing through them than the average old school small block but can it be that much? I want to get as much of the previous posts calculations right so I can mark my stick if even necessary.
Don't forget about a quart to wet the insode of the engine and a half quart or so for the oil caught in the fog surrounding the rotating assembly. Put one more in for your filter. 2.5 + 5.25 will bring you to 7.75 qts — call it 8 qts. Lay your windage tray in the pan and fill to about a inch blow the tray maybe a quart— probably pretty close to where you are now. Add a half a quart to a quart for oil in the return cycle to the oil pan and you should be right at or near 9 to 9.5 qts. Mark the level on your dipstick as your fill to level. Viola! You're done.
