Old 08-06-2022, 08:35 AM
Mike_Gr Mike_Gr is offline
If you dont find any issues with the control arms or anything that seems bent, I use something very similar to the second part you linked and have had good luck. I run a fairly aggressive alignment with -3 degrees camber, +5.5 degrees caster and 0 degrees toe in the front.
