Old 08-08-2022, 06:14 PM
MBE MBE is offline
Cobra Make, Engine: Ford DOHC
Originally Posted by sunman View Post
There is a video of one installed on a 47 Ford truck on the Ford Truck Enthusiasts forums.
Has a Mustang 2 front end and works good.
Drift cars and dirt track been using it for years.
Pump has an input for a speed signal and runs all the time without one.
I’ve read here years ago the best ratio is the power rack with the lines looped no pump.
The pump is loud needs a box around it to quiet it down.
I will have to research this further; there must be a "best" pump, maybe a Ford unit (other than the Toyota if it is too loud) that runs when needed at pressures that match up to whatever is needed to power the steering on my Cobra. From the pictures on the internet, it looks as though the Mustang 2 manual rack and powered rack are interchangeable using the same mounting holes, steering shaft and possibly tie rods and tie rod ends.
I will report back with what I find.
Thank you,
Bob
