Old 08-14-2022, 01:09 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
If the only reason you are installing the PCV system is to get the car registered the system I described above works as needed, then you can remove it and return your system to the cleaner appearance without the PCV. As I stated I just went through the inspection process with the PCV installed as I outlined above and it was passed without issue. If you want a permanent system you will want to supply the PCV gasses to all the cylinders equally, but then why?
As EZ$ pointed out he had to take it a step further, in my opinion it all depends on the inspector as to what they want to see.
