Old 08-15-2022, 10:26 AM
tims210 tims210 is offline
Cobra Make, Engine: Backdraft - Coyote
Originally Posted by eschaider View Post
Every one, there are only a half dozen or so and you already know you have a problem with cam phasing so you ought to go to the commanded vs reported cam phasing as a starting point.
Be sure to check your OBD II error codes if any are present. They can save a lot of uninformed stumbling around looking for a problem.
I don't know if I follow you on the command vs. reporting. I'm assuming reporting pertains to a scanner reading a value but how is a command initiated?
