Old 08-15-2022, 11:31 AM
tims210 tims210 is offline
Cobra Make, Engine: Backdraft - Coyote
Originally Posted by twobjshelbys View Post
Most likely they will match. The actual "delivered" is based on the rating of the fuel injectors. It's not a volume measurement but an calculated amount based on the lb/hr rating of the injector and the pulse width of the firing cycle.
So, have you verified that the injectors and the tune match?
No. Not sure how to do that. I forgot to mention that I also have a Innova scanner I used as well. Maybe I can check from there? It has the option "scan for codes > system status > all module scan". I think I may have stated this before but both scanners show fault codes.
