Old 08-15-2022, 11:50 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by tims210 View Post
No. Not sure how to do that. I forgot to mention that I also have a Innova scanner I used as well. Maybe I can check from there? It has the option "scan for codes > system status > all module scan". I think I may have stated this before but both scanners show fault codes.
You'll have to expose (even possibly remove) one of the injectors to get the manufacturer's part number. If it's a stock crate engine they should be able to tell you what they have installed. Then check Lund to see what he's programmed into the tune.
Tony
CSX4005LA
