Old 08-29-2022, 04:48 AM
Sycraft's Avatar
Sycraft Sycraft is offline
Cobra Make, Engine: ford 302
I looked into it, but was cost and use prohibitive. The sway bar mounts to the lower arms, so that creates an additional challenge when building a heim jointed lower arm. Better off boxing off original arms and cutting off spring mount as others have done. Replace the bushings with poly (I did). creates a solid rear tracking. Many use the upper fox body adjustable links for the 8.8 diff to set pinion angle and such, mine have speherical bearings to minimize axle roll and movement.
