Thread: Low on power?
Old 09-05-2022, 08:59 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by cobragene View Post
I can blast off in second gear hold the brake lightly and only burn about 30’ then grabs and goes, I hear some can just jab it in 3rd and break them loose, I am lucky to jab it in 1st and break loose if it’s cooler out. FE 428 10:1 780 Holley vac sec open 3/4-7/8 with the lightest spring ,tall oval air cleaner, RPM performer, edelbrock heads, 36 total timing, hyd. Cam .539 280 ,at .050 230 lobe sep 110. 350 gears 29” x12” MT S/R tire, WR toploader. Runs great I just feel I am leaving some on the table, may try to get some Dyno and tune time. The tubes in side pipes are rather small, I guess that would be a good and cheap place to start? Any feed back would be much appreciated.
Remove 780cfm Holley Vac Sec carb
Replace with 650CFM Holley double pumper-04777C
Try it fresh out of the box, do not adjust carb, do not adjust timing just yet.
In addition, maybe check tire pressure in rear tires, want to burn out more, add additional pressure
Bill S.
