Old 09-08-2022, 05:05 PM
bobcowan's Avatar
bobcowan bobcowan is offline
I'm still struggling with this.
With engine ON, step on the brake pedal. Brake lights come on. But parking lights and dash lights also come on.
Turn signals work.
With the dash light switch, the parking lights, dash lights, and headlights come on, but not the brake lights.
I have unplugged all of the signal outlets from the harness, front and rear. No change.
I took the dash apart, looking for bad wires and connections - couldn't find any.
The brake pressure switch is mounted to the side of the master cylinder. There is one 20g red wire going in to the switch - power.
- if I disconnect that wire, no lights with the brake pedal
There are two wires coming out of the switch. A large red wire with no label.
- If I disconnect that wire, no change
And a smaller black/red wire labeled "Stop Lights"
- If I disconnect that wire, no lights with brake pedal
My thought is that there is a problem somewhere between the brake pressure switch and the dash. The supplied schematic is no help at all. All it shows is one wire from the pressure switch going directly to the brake lights.
My next plan is to disconnect the factory stop light wire, and run a new wire back to the outlets.
Any other thoughts?
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
