Old 09-10-2022, 05:13 AM
spdbrake spdbrake is offline
Originally Posted by tonywyso View Post
How did you like the aluminum flywheel and what brand dual set up are you going with.
I love the 14lb flywheel currently installed. Revs quick, and decels quick. I have accidently taken off in 3rd a couple of times so torque does not seem affected.
I changed from my solid roller 3000-8000rpm to a hyd roller 1500-6500 and it a lot more torquey. No more low rpm trailer hitching.
Was going to go with a McLeod https://www.summitracing.com/parts/mcl-6913-07 but their stuff never comes balanced.
So then put a Ram https://www.summitracing.com/parts/ram-50-2259 in the cart. But after looking at pricing for the flywheel insert, grinding and match balancing I'm going with a Ram https://www.summitracing.com/parts/ram-75-2259
My 408W is internally balanced but Ram does sell external balanced kits as well.
Standard throwout bearing, and fork. Adjustable pivot ball. I have a Lakewood bellhousing and external hyd slave setup.
