Thread: Vent to Nowhere
Old 09-14-2022, 04:23 AM
gcarm gcarm is offline
Cobra Make, Engine: G-Force with LS1
Default Vent to Nowhere
Glen,
Thanks for the detailed explanation with photos.
So two things I need to do:
1) Pipe the filler overflow tube back into the tank
2) Place an earth strap from the filler neck to the chassis
One thing I fogot to mention - the tank has a rollover valve installed which is also used to 'vent' the tank. I have connected this to the charcoal cannister which I believe is where it should go.
So its really only the overflow when filling that I need to be concerned about. I'm thinking it may be best to feed the filler overflow tube into the tank vent/rollover outlet via a 'Y' connection. Does this make sense?
Greg
