Thread: Low on power?
  #25 (permalink)
Old 09-21-2022, 08:49 AM
jhv48 jhv48 is offline
From the Holley website:
“For high performance engines a carburetor with mechanical secondaries has an inherent advantage over a carburetor with a “controlled” secondary system (air valve or vacuum diaphragm). This is possible because a controlled secondary carburetor, until it reaches wide open throttle, will not have as great a pressure drop below the throttle plates as would a mechani- cal secondary unit. The greater the pressure drop below the throttle plates the more dense will be the fuel/air charge to the engine and, hence, the more output.”
Swap out the carb and be done with it.
Jim
