Old 10-04-2022, 12:44 PM
Imlumpy Imlumpy is offline
Cobra Make, Engine: Antique and collectibles
Default Fitech just stopped running
Here’s a heads up if anyone else with a fitech system with force fuel suddenly loses fuel pressure . Car has run fine for two years then just stopped running . Everything looked to be in place , mechanical pump seemed to be pumping and electric pump was running.Went almost nuts trying to figure out why the system had no fuel pressure. Pulled the pump out of the force fuel and bingo ! There’s a small section of rubber hose that goes from the electric pump to the aluminum housing , had a hole blown in it . Put a new piece of hose in , put it together and it fired right up . Lots of head scathing, simple fix in the end .
