Thread: It Happens
Old 10-05-2022, 01:27 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by hauss View Post
Well I did it again. Went to a car show the event was held for a friend with severe park ins disease AS I was leaving I wanted to give my friend ,something to smile about so I let the horses out of the barn and did a nice big burnout! By the time I got home the oil line to the pressure sender had cracked and I lost about three quarts of oil.Also car would no longer go into 5th gear. So I removed the transmission from the car while doing this I noticed my drive line bolts were all loose not only that but I snapped off two bolts on my axle that hold the CV joint to the flange on the rear end. I guess I should thank God I did not hit anything. One good thing now when I go on a long drive I will Know everything will be tip top.
I have to ask, when is the last time you actually tech'd your car? I go through certain items before I take it out of the garage, tire pressure, oil levels, knock offs tight.......Generally go through the car once a month or once every other month, depending on my use, to make sure everything is buttoned up.
Bill S
