  #27 (permalink)
Old 10-06-2022, 05:42 AM
strictlypersonl strictlypersonl is offline
Originally Posted by cobragene View Post
Could anyone possibly make a schematic for this shunt I have an EM so my wiring is different, I already had to replace my amp gauge because it overheated, or should I just convert to volt gauge? I assume any ignition hot wire could be used for the volt gauge? Thanks
Your ammeter has two main terminals. Each one has one (or more) heavy wires. All you do is add the shunt wire from one main terminal to the other, leaving all the other wires in place.
If you have male spade terminals on the gauge, each end of the shunt wire must "Y" and have a male and female so that the original connections can be retained.
