Thread: It Happens
Old 10-06-2022, 04:48 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
I do check but the cv bolts on the axle are inside the cv joint so I am only able to view from the backside where the bolts stick out of the flange. As I was rotating the drive line I noticed unusual play in the axle. as far as the oil line I will replaces with black iron instead of brass. The transmission is a TKO 600 and I broke the 5th gear rail witch happens more often than you would think with big hp cars.
