Thread: Side Pipes
Old 10-09-2022, 06:10 AM
BDR0572's Avatar
BDR0572 BDR0572 is offline
Cobra Make, Engine: BDR, Roush 402R
Originally Posted by Say When! View Post
Hi All , I have a 2022 Backdraft with a 427 Chevy. My mate bought exact same and we both have the most annoying rattling from the side pipes on deceleration and just above idle , not only is it anoying but embarrasing .
Anyone figure out a solution or alternative pipe that has removed this sound?
yep, it is the aft support brackets on mine, i bought a small dia washer drilled the hole to allow bolt and used as a shim tighten up fit also had an issue with a bracket hitting mount .. had to grind it down about an 1/16 { bracket is wider than spacer,} it will stop brackets on pipe from pinching and tightening up, leaving aft support bracket to rattle at stops and so far no more rattle
