Old 10-12-2022, 05:35 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
I opted for a voltmeter instead of an aamp gauge. When I wired my instruments, I read the instructions for doing this and called Doug. Doug said all I had to do was connect the two large wires that went to the ammeter together with a piece of metal. I did this and put heat shrink over the connection. I then installed the volt meter using a switched 12v wire and ground.
This has worked fine for five years. Is there any downside to this method?
Chris
