Old 10-12-2022, 03:07 PM
WordMan WordMan is offline
Cobra Make, Engine: None, yet.
Originally Posted by bobcowan View Post
If you use a .060 head gasket, that gives you a quench area of .066. That's way too much. Should be much closer to .040. You need a gasket closer to .035'ish.
Be sure to calculate dynamic compression with the big cam you're planning on. Keep that around 8.0 or so.
All the head gaskets I can find list .050 as compressed thickness. Never mind... found them.
