Old 10-14-2022, 04:39 PM
6TNCRZY 6TNCRZY is offline
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
I had an issue with 649, the rack would slide back and forth under pressure.
I would turn, then on a straight the steering wheel would be crooked, turn the other way and the wheel would be crooked the other way. If the rack is twisting in the frame on turns the steering could feel very strange. New bushings fixed the issue on my car. My new ERA car uses a Mustang 2 rack mounted with through bolts, a much better setup. You night want to make sure the shaft bushings in the rack and the inner tie rod ends are tight.
