Old 10-19-2022, 02:40 PM
Kojack70 Kojack70 is offline
Cobra Make, Engine: Backdraft - Roush S/B 427
This is actually backwards, Dot 5 does not absorb water. Dot 5 is silicon based and was developed to be used in cars where excessive moisture would cause problems. Dot 5 also has a higher boiling point and offers better corrosion, rust resistance and generally lasts longer than Dot 4. I don't see any advantage to changing. Incidentally, I'm running the Wilwood brakes on mine with no issues.
Originally Posted by bobcowan View Post
Why? You've been driving it like that 17 years. What makes you want to change now?
The big problem with 5 is that it can attract water, which then ends up in the calipers. And that's bad for a number of reasons. As long as you flush the system with new DoT 5 fluid regularly, it won't be an issue.
