Old 10-19-2022, 04:45 PM
patrickt patrickt is offline
Originally Posted by CHANMADD View Post
If the Fan switch is too low, it will run all the time.
This is the fan thermo switch ERA uses. It's a 75 Centigrade switch:
Switch, fan thermo -- 1980-1984 VW Rabbit, Jetta: 823 959 481/75
Why would VW even make a fan switch that ran the fan all the time? If you wanted it to run all the time you wouldn't need a switch. If your lower radiator hose can't get below 167 degrees Fahrenheit then something is not right.
