Old 10-24-2022, 03:35 PM
Pmccooey Pmccooey is offline
Thanks for all the help. I had a little time between rain storms to dig into it. Found the sending unit int the middle of the tank towards the front. Ground from the sending unit tested good. Traced the green sending wire to front. It might be pinched on body/frame over by the left rear wheel. I pulled the drivers seat and under the carpet are two wire bundles with connections. I disconnected the gas gauge harness under the seat. Test from fuel tank showing 0 ohms. Tested towards the gauge with potentiometer. Fuel gauge showed E when disconnected. With 0 ohms applied the gauge goes to F, it goes down to 1/2 at 45 and just above E on 90. The fuel tank was drained. I’ll see if I can clear the green wire from the pinch and drop tank to see if it’s getting grounded out on the pinch or somewhere else. To be continued!
