Thread: Turkey Pan
Old 11-02-2022, 11:39 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Kojack70 View Post
Hi Bill,
For my own curiosity, is it the turkey pan itself, the filter setup or combination of the two which will rob the horsepower?
Thanks
Don
Don,
It's actually the restriction in filter size that causes the issues, you may not be able to install a large enough filter (see formula below) to get the proper airflow needed for the best performance. If you are racing, and spend 80% of your time over 130mph, a turkeypan works quite well when combined with proper sealing with the hood scoop, below that, it's just a nice show piece and nothing else. Personally, I got rid of the turkeypan and smaller airfilter assemblies a number of my Cobras. Replaced with a K&N 66-3040 unit. Both big and small displacement motors, in a number of my Cobras, including my current ERA-FIA.
I do suggest that before you spend any money, no matter which direction you ultimately choose to go, you need to see exactly what CFM worth of filter assembly you need to properly feed your engine.
Using the simple formula
A= effective filter area
CID=engine displacement
RPM=maximum RPM expected
Using the CFM formula of height X diameter x 6 x 3.14
Hope this post is helpful.
Bill S.
PS: The 14" extreme filter top flows 500cfm by itself, just saying.
