Old 11-02-2022, 06:31 PM
cobragene cobragene is offline
Cobra Make, Engine: Everett Morrison FE 428
Default Replace old rear seal?
428 fe I have a pin hole leak in my cast aluminum oil pan and of course it’s blowing back on bell housing, inside bell is dry, no oil running down from up top I did a dye test, I am going to drop trans for another reason and seal the oil pan but while i am in there should I also replace the 23 year old rear main seal? What type of sealer should I use on the pan?
