  #56 (permalink)
Old 11-14-2022, 08:00 AM
Argess Argess is offline
Now that led to good information for me. T-Y I wanted to use the Wilwood 120-10937 dual piston D52 caliper but their drawing showed it wouldn't fit.... for 12" rotors. I thought I had measured mine and got 12", but the ERA site says they are 11" so they will fit!
Note: I used a tape measure and as the darn knock-off hub was in the way; no doubt my measurement was incorrect.
As I'm trying to get more braking power, I didn't want to go with the Dynalites as the total piston area was much smaller than the Wilwood D52 or my GM D52s. Also it's nice for me to use D52 pads which fit the same in the GM calipers or Wilwoods.
and I assume yours work fine?
EDIT: There is one slight problem with the Wilwood D52 units. They use a 7/16 x 20 banjo bolt so my existing flex lines would need to replaced or reworked. Not a big deal I suppose.
