Old 11-26-2022, 05:16 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Heat soak issues are frequently electrical components.
I would have a spark tester handy and check for spark when this happens.
Also, you should be able to look down the carb and see if fuel squirts from the accelerator pump. Even better would be to install one of the in-line fuel pressure gauges into your fuel log. They are cheap from Summit and others.
You really need to know if you are losing spark or fuel.
John
