11-28-2022, 06:32 AM
Cobra Make, Engine: SPF#0760
If you know which new style headlamp you want the same company usually sells short adapters if their lamps lamp sockets are not standard. I have H4's in my original WIPAC lamps. But your lamps are different from mine. Mine are not sealed beams. Early cars also had a second small bulb in each headlamp that functioned as a running (parking) light. Newer cars like yours don't have that 2nd bulb so any standard headlamp will work. Picking up a power point is easy under the hood if needed. ( i think the extra hot is for the glow ring) I have a Wiring Diagram available for your series chassis if need. Feel free to message me with questions.
Blas
SPFWiringDiagrams@Comcast.net
