Old 06-27-2002, 12:52 AM
MoonDog MoonDog is offline
Send a message via ICQ to MoonDog
Default Rear Spring Setup
Hope you guys can help...
I am going to replace my rear (Jag) springs and shocks for better handling, ride etc and I heard that some peole have set their suspension using only 2 springs/shocks instead of the usual 4.
Obviously, the spring rates need to be doubled..
Is there any problem with this setup?..for example extra twist on control arms?.. mountings..
If this setup is Ok..then should the setup up be on rear or front of control arm..
Any help appreciated
Regards
Moondog
