Old 12-12-2022, 03:16 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Default Good Tool or Part Finds Thread:
Purchased a new pressure testing kit for my cooling system with both pressure and vacuum capabilities. It came with a rubber plug and clamping device for connection to the radiator instead of a standard radiator cap. I really did not want a kit with 12 different caps that I would never use. While the rubber plug might be good in theory, when I was about to test a cooling system on a friends Corvette, I noticed that his tank connector was plastic. Better judgement said “stop” because the pressure testers clamp uses the tanks lip as a clamping point to set the rubber plug in place. I found a proper cap with matching hose connector online. An excellent find. They have 3 cap versions available, mine was their #3. Got it thru Walmart online.[IMG][/IMG]
Blas
SPFWiringDiagrams@Comcast.net
