Old 12-31-2022, 05:11 AM
1795's Avatar
1795 1795 is offline
Yes, you do end up removing more than you install! Glad that you put the full list of everything that has to be removed for others to see, I was running out of time when I was posting and it is a lot. As you said, you have to remove the interior in order to get the tunnel cover off. It's a lot easier getting those bolts underneath the dash for the forward struts off with the seats out of the way, especially on the drivers side. Once you get the engine and transmission in, you can then make sure that the tail of the transmission and the differential have the correct orientation and you can measure and have your driveshaft made.
Getting the hoses made for the radiator takes a little bit of hunting to find the right ones, but not too bad. Having a lot of helping hands is nice. I have done the install by myself twice, and it is not easy trying to line things up and move the engine by yourself. Nor is lifting a 100 lb transmission into place by yourself. A helpful way to aid in installing the transmission that I have seen on the forum and used is to purchase four bolts (6-8" long) of the proper thread for the bell housing, cut the heads off of them and then once the engine and bell housing are installed, thread the bolts into the bell housing. You can then slide the transmission down the bolts and remove them one at a time after the transmission is properly mated, and install the connecting bolts. Takes a lot of pressure off your back, chest and arms.
Looking forward to seeing photos of the completed project.
Jim
