Old 01-04-2023, 07:21 AM
patrickt patrickt is offline
Originally Posted by Ron61 View Post
Patrick,
Did you make that tool or buy it from some manufacturer? And if it spun your tire on the floor your spinner must have been a little more than just a little tight.
That tool is 100% homegrown, as we say.... It started out from the Finishline billet aluminum spinner piece that I had a machinist cut and mill to fit a big impact socket. That worked well, provided you had an impact gun and a compressor by your side. Then, when I was showing it off to Silverback over on the TC site, he asked why I didn't use a torque multiplier on it so you could remove it by hand. So I bought that big ass torque multiplier that puts down roughly 5,000 ft/lbs of torque. That worked better, but tended to torque upward a bit as you were cranking it. So I built that clamp bracing contraption using a really strong clamp from Alabama Clamp Co. along with all Grade 8 hardware and all going through three stacked 2 x 10's. It quickly disassembles and is really kind of fun to use. That build was outlined here: I Can Remove My Spinners With One Finger But I agree that I might have put that spinner on a little too tight. I only use that contraption to remove the spinners, never to put them on. I use the traditional big lead hammer for that, but I think I suffer from the "give it one more whack" syndrome. But it's not like the car was doing a front end burnout in the garage. As I would torque it up by cranking the handle the tension increases and then you hear a tire squeal and the tire spins maybe a half inch and all your torque is gone! At first I thought "well great, what am I going to do now?" And then I realized all I had to do was stick a broom between the back of the seat and the brake pedal and the problem was gone. I still probably overtightened them when I put them back on. That syndrome is hard to kick.
