Old 01-23-2023, 11:56 AM
eschaider's Avatar
Originally Posted by cobragene View Post
Sunman I am dealing with Modern drive now about the oversize
If you go to the MDL site the pilot bearing you most likely want to use is, click here => FE Pilot Bearing
This bearing is solid bronze, 1.850" OD with a 0.670" ID and 0.900 tall for a Tremec 26 spline input shaft. If your trans uses the smaller 0.590" OD input shaft you have two other choices.
Choice #1 1.850" OD with a 0.590" ID 0.500" long (standard length)
Choice #2 1.850" OD with a 0.590" ID 0.900" long (extended length)
Link to Choice #1 => Std Length FE Brg
Link to Choice #2 => Extended Length FE Brg
Pick your poison ...
