  #22 (permalink)
Old 01-28-2023, 07:21 AM
Unique427 Unique427 is offline
If it's a Suburban with 5.3L it will struggle pulling a loaded 20x8.5
enclosed trailer on extended warm weather travel that's not
flatland. Transmission cooler is highly recommended as well.
You'll also need a trailer brake controller. I'm guessing your
Suburban is already equipped with the OEM max tow package
so you're GTG with what's mentioned above.
Here's a starter list to set your checkbook on fire............
A weight distribution hitch with sway control if going
the 18-20 foot enclosed route (+5000 lbs loaded).
Something like this:
https://www.campingworld.com/equal-i...=sway-controls
A 2-5/16" ball hitch that will take a 1-7/8" thin wall socket and
torque wrench capable of +300 lb.-ft. to install. Look here:
https://www.campingworld.com/equal-i...ia.-59258.html
https://www.etrailer.com/Automotive-...ALL643216.html
An adjustable shank.
Read up and understand "Tongue Weight". Look here:
https://www.etrailer.com/faq-how-to-...ue-weight.aspx
Rear view mirror extenders (or camera setup) to see
behind/around the trailer. Look here for example:
https://www.campingworld.com/rear-vi...tem-82551.html
https://www.etrailer.com/Towing-Mirr...eID=2016100947
Axle straps front and rear to hold your car in place.
If your Unique is like mine, there's (2) frame mounted
tiedowns in the front for securing straps to trailer floor D-rings.
The rear has a single frame mounted center tiedown. I
suggest not using that and secure with straps around the
axle each side. If there's aggressive or evasive moves
while hauling, the rear can shift and slide inside
the trailer if only utilizing the center hold down fixture.
