Old 01-28-2023, 03:30 PM
tkb289 tkb289 is offline
Hi Glen,
Glad that you finally have some clutch parts and can make more progress.
A HTOB has its place, particularly in modern cars with limited space and tight machining tolerances.
I think from a maintenance perspective, an external slave cylinder & clutch fork is the way to go for your Cobra, provided you have the space, or can make the space with some clever cutting & patching.
Based on my experience, a few things to keep in mind. I bought a slave cylinder bracket & rod kit that was pretty good, but was not totally happy with the alignment & geometry. I wound up modifying some of the parts. I was also not able to find a suitable rubber boot to help seal off the area between the clutch fork and the bell housing. Was told by a few folks it’s not necessary, but I was able to make something that worked reasonably well. You may have a different experience based on your car and the parts you are able to acquire.
Given your engineering and fabrication talents, I know that you will came up with a first rate solution.
- Tim
