Old 02-18-2023, 06:11 PM
COBRA-SPO2400 COBRA-SPO2400 is offline
Default Superformance Quick Jack Spacer tube length?
Hi all,
First post here, recently acquired SP02400 and I'm changing out the bumperettes for quick jacks.
What's the correct size (length) of the tube spacer (ferules) for quick jacks. When I took overriders off I had a two pieces of tube on each bolt. Meaning there was the one you could see then another small pieces behind the body that fell out when I pulled threaded rod out. I imagine it's better easier to install if they are one piece.
Just need to know correct length for proper spacing. Hope that makes sense to you all; thanks in advance for any help!!!
Cheers!!
