Old 02-20-2023, 06:51 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
A better reference to use as follows:
The tubes in front should extend to 1” behind the fiberglass of the front radiator opening directly across from it. The rear tubes project out approximately 2”.
You will want to use washers against the frame mounting points to fine tune the projections so the quick-jacks are perpendicular to the ground. Remember, cosmetic use only.
Happy to send photos if you email me. (See below)
Also: Just for fun, start a note pad to record which quick-jack and how often these little sweeties jump out take a chunk out of your shins when you walk by them carelessly.
Left rear is ahead on my list with right front a close second.
Blas
SPFWiringDiagrams@Comcast.net
