Old 02-27-2023, 04:02 PM
ppbmac ppbmac is offline
Default Hydraulic Bearing line fittings?
I have new RT4B and the hydraulic line fittings from the RAM hydraulic bearing doesn't want to thread onto the steel clutch line fitting from the master cylinder. Is it possible the line fitting on my BD is metric and the RAM bearing line fittings are standard? If so, does anyone know the thread type/size adapter I would use to make it work?
Thank you.
