Old 03-06-2023, 11:31 AM
Capt Nobody Capt Nobody is offline
Cobra Make, Engine: 2022 Superformance MKIII-R
Originally Posted by twobjshelbys View Post
My Roush 427IR got about 9 MPG in city, but 12-13 on highway in 5th at 75.
What generation of EFI do you have? If it is the Accel system (older generation) it's going to take a lot more than 2 hours since the tables are not completely populated and it will take time to discover the gaps. As discussed earlier, if that is what you have you would be well advised to switch to another system or go back to the carb version (427R). (under a grand vs 4grand). And a carb will do fine for your usage model.
Tony - I wrote a check for a little over $50,000 less then 5 months ago to have a 427IR & TKX trans installed in that car. While I can appreciate you thinking outside the box, the notion of reverting to a carbureted engine has to be the most ludicrous suggestion of all suggestions in the entire suggestive world.
I know my ECU is a FAST. Bob seemed relieved when informed.
