Old 03-18-2023, 04:09 PM
oilerfish oilerfish is offline
Default Buddy Bar valve cover
Found and bought for a song a set of Buddybar valve covers.
They cleaned up pretty well with vapor blasting and happy with the look ( That air filter will find another home..).
However, someone has removed the steel tube in the oil fill side and the internal baffles from both. Thinking about filling the oil fill
hole -1 3/8" - with a Granatelli Motor Sports Valve Cover Baffle, part # 451000, this has an id of 1" so can get a breather to fit that.
That would cover the oil fill side but what do I use on the PCV side to stop oil from being sucked into the PCV valve? Id of PCV side is 1".
