03-23-2023, 09:52 PM
Ok,
Originally Posted by Alfa02
I would say pull the top off (Careful with the floats) and just soak the gas out with a rag or paper towels, than just a shot (Low Pressure) air to the jets. That should do it, Hope that help's Paul, Cheers Tom.
Originally Posted by peterpjb
huge problem, the fuel in the jets will go rank within six month, and the jets will be clogged, you have to disassemble the carburetors before storage and clean every part and every jet from fuel, it is much less work than disassemble afterwards
are you saying that what Tom says is not enough or validating that this should get all the fuel out, as you both seem to be suggesting?
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
