  #23 (permalink)
Old 03-30-2023, 09:12 AM
undy's Avatar
undy undy is offline
Originally Posted by Rig Man View Post
Ford FE speciification for 482 cu in 10.5:1 Compression 4.125" x 4.125" bore x stroke producing 582 HP @ 6000 RPM W/ 593 ft/lbs Tq @ 4680 RPM
BBM 427 Side Oiler Block
Edelbrock Heads - CNC by Blair Patrick
SCAT 4340 Forged Crank
Molnar 6.7" H Beam Rods
Mahle PowerPak Pistons
Bluethunder Medium Riser Manifold
Custom Solid Roller Camshaft 238/242 114 by Blair Patrick
Crower Enduramax Solid Roller Lifters
T&D Custom Rocker Assembly - Blair Patrick
Aviaid Oil Pan & Dip Stick
Duramax Ignition
Custom Holley 4150 850 Carburetor
Your displacement is actually 445" if your specs you listed are correct. My KC built, Pond block side-oiler is a true 482" and it's 4.25" x 4.25".
Too many toys?? never!
