Old 06-27-2002, 09:10 PM
GUMBALL GUMBALL is offline
Default Need quick answers............
Poop!
Flywheel and starter teeth were not aligned properly using Lakewood bellhousing. (they are not a good fit)
Need a new ring gear and bellhousing pronto as teeth are history on both. (leaving for SAAC Tuesday)
I have been told stock bellhousings fit great.
Questions:
1) Where should I look for a stock 427 bellhousing?
2) Are all FE bellhousings the same or are they different for 427 vs 428?
3) Will I be able to find a steel bellhousing or should I settle for an iron. (very short on time, right now I need a band-aid)
4) How involved is changing the ring gear?
5) Where do I get a ring gear for an aluminum McLeod flywheel.
6) Should I just buy another $400 flywheel in the interst of time?
Help!
Regards,
John
Better to have and not need than need and not have!
