Old 04-07-2023, 03:27 PM
joyridin''s Avatar
joyridin' joyridin' is offline
Plexiglass is easy to bend. Just heat it up. Lexan is a bit more time consuming. With Lexan, you need to bake it at 250 degrees for about 45 minutes, then turn the heat up to 350 for about 20 minutes. After that, it is smooth sailing.
Lexan has a lot of moisture, so you need to dry it out first or you will get bubbles. In both cases, work fast or you will be heating it again.
