Thread: Signal Lights
Old 06-28-2002, 04:52 AM
Bob Putnam Bob Putnam is offline
The following assumes that the front signal lights aren't working either:
The signal lights are on fuse 4, the brake lights on fuse 5. However, fuse 4 also services the fan and voltage regulator, so if the car is charging, you don't even have to check the fuse.
Check the connectors at 8 in the wiring harness, and the connection between the gang connectors C and D.
And the flasher.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
