Old 04-30-2023, 07:38 PM
eschaider's Avatar
Originally Posted by Ace23 View Post
I agree. Using an in-tank fuel pump and a nice multi-port injection system would likely be a world of difference.
Not just a multi-port EFI but a Mass Air Flow (MAF) based multi-port EFI. A Speed Density EFI system will be a significant improvement over carbs, from a tunability perspective; however, significant changes in air temp, barometer, humidity etc., are extremely difficult to accommodate with a Speed Density fueling model. As a result, without a new tune, you still experience the power reduction we all so dislike.
The MAF-based EFI fueling model measures the mass of air entering the engine, making AFR determinations and fueling adjustments in real-time, no matter the atmospheric conditions. Remember, AFR is lbs of air per pound of fuel.
This doesn't sound like a big deal until you spend your dollars on your favorite multi-port Speed Density EFI system and discover not much has changed from your carburetted experiences, except the amount of money that is now in your pocket.
